Re: New print surface material? October 19, 2015 03:17PM |
Re: New print surface material? October 23, 2015 07:13PM |
DjDemonD
Got my 200mm square sheet and installed it on my i3 with mk3 aluminium heatbed, using bulldog/binder clips for now. I can auto level using an inductive sensor just had to change the probe offset in Marlin to include the thickness of the printbite sheet. The clearance between my sensor's detection distance and the nozzle to the printbite is only 0.3mm but it is enough for now (going to change to a capacitative sensor later anyway and I am running my inductive sensor at 5v so the detection distance is reduced). First print with ABS and I'm really impressed, great first layer with nice smooth finish. The part remained well attached down to around 85 deg C when I could snap it off the printbite.
No more hairspray and since I was previously printing directly onto the aluminium bed, no more little piece of kapton tape over the thermistor hole, and it loses heat a little more slowly than the bare aluminium so less bed cooling in my cold garage, so result all round. Well done Mutley3d.
I would love a 200mm circular piece for my kossel mini now.
Re: New print surface material? October 23, 2015 07:57PM |
Re: New print surface material? October 25, 2015 02:04PM |
IMarsbar
Just like to add, tried with Nylon last night, printed worm gear so thin and tall, head 265, bed 115.
Printed spot on. Released off bed once cooled no pressure, felt like no diff to printing abs.
My first time with Nylon so don't know how hard it is to normally print with it
Re: New print surface material? October 25, 2015 02:08PM |
Mutley3D
IMarsbar
Nylon is traditionally known as a problem material to print. Often wood or Garolite, even cardboard and tapes have been used with varying degrees of success. These clearly can be a pain due to levelling and height issues not to mention the messing about setting up new bed material just for a Nylon print.
Looking like its now a one size fits all with regard to a printing surface for differing materials. I have also printed Polycarbonate which is known to be a problem for adhesion, onto PrintBite. Sticks exactly the same as everything else and self releases once cooled. Howzat
Re: New print surface material? October 26, 2015 03:31PM |
Re: New print surface material? October 26, 2015 09:58PM |
Re: New print surface material? October 27, 2015 07:39PM |
Re: New print surface material? October 28, 2015 05:07AM |
Re: New print surface material? October 28, 2015 06:54AM |
Re: New print surface material? October 28, 2015 07:58AM |
Re: New print surface material? October 28, 2015 08:01AM |
Re: New print surface material? October 28, 2015 08:13AM |
Re: New print surface material? October 28, 2015 08:37AM |
Re: New print surface material? October 28, 2015 02:10PM |
Mutley3D
Hi Treito, asbo, - Use a double sided tape for sticking down vinyl flooring. Its thin, cheap effective and available from all decent homeware or hardware stores. Otherwise you have the 3M 468P tape option but this is not so cheap. It is advised to stick down the whole surface completely. If you stick it down around the edges it may not work as it may bow or warp under heat stress, and you will also not get the same heat transfer. Please follow the instructions available at [mutley3d.com]
All orders upto 5pm yesterday evening have shipped. If it hasn't arrived yet it will be with you in the next couple of days
Re: New print surface material? October 28, 2015 02:47PM |
Re: New print surface material? October 28, 2015 06:58PM |
Re: New print surface material? October 28, 2015 09:24PM |
Re: New print surface material? October 29, 2015 09:25AM |
Re: New print surface material? October 29, 2015 10:45AM |
Re: New print surface material? October 29, 2015 01:04PM |
Re: New print surface material? October 30, 2015 12:19PM |
Re: New print surface material? October 30, 2015 12:48PM |
Re: New print surface material? October 30, 2015 03:03PM |
Fatlab
Mutley3D,
I've been trying to print onto the PrintBite from my Ormerod 1 for the last couple of days and I'm having major problems getting the first layer to stick to the surface. I'm now using Faberdashery 1.75mm PLA having moved off some bulk white PLA that just wouldn't stay put full stop.
The settings I've tried are all of the combinations in 5 degree steps of bed from 55c to 70c and hot end 185c to 210c. I've cleaned the print bite with both pure acetone and isopropyl alcohol but it makes no noticeable difference. The Ormerod 1 was previously printing onto blue painters masking tape with a cold bed and 185c at the hot end and stuck every time. I'm using Slicr to generate the gcode files and I've tried both 0.24 and 0.3mm first layer heights. The problem starts with the initial loop of the print where it does around 60mm movement before the filament is extruded. After that the next 50-80mm appears to stick but then lifts as soon as there is any lateral pull. When the loop does complete successfully its then the first layer infill which fails to adhere at the edges of fulling in a shape.
The 200x214mm bed is level to within 0.05mm at the centre and corners before level calibration. Z axis homing is done with a sheet of A4 paper when the hot end is at temperature and the bed temperature checks out with an infrared thermometer. I've tried setting Z0 to when the nozzle first contacts the paper and also at a further -0.05mm and -0.10mm respectively. The lower Z0 gives slightly better performance but another -0.05 would have the nozzle taking the weight of the print head.
Any advice would be appreciated as I'm running out of ideas.
Regards
Dave
Re: New print surface material? October 30, 2015 03:35PM |
Re: New print surface material? October 30, 2015 05:08PM |
Re: New print surface material? October 30, 2015 05:15PM |
WZ9V
What window cleaner are you using?
Re: New print surface material? October 30, 2015 05:22PM |
Re: New print surface material? October 30, 2015 06:04PM |
Re: New print surface material? October 31, 2015 12:01AM |
