Re: An alternative to buying a bad kit for $300-500 October 29, 2016 09:07AM |
Extrusion tuning October 29, 2016 11:24AM |
Re: Extrusion tuning October 30, 2016 10:53AM |
the_digital_dentist
Moving on to other things...
Re: Extrusion tuning October 30, 2016 01:01PM |
Re: An alternative to buying a bad kit for $300-500 October 30, 2016 01:33PM |
Re: An alternative to buying a bad kit for $300-500 October 30, 2016 02:44PM |
Re: An alternative to buying a bad kit for $300-500 October 30, 2016 08:13PM |
Re: An alternative to buying a bad kit for $300-500 October 30, 2016 10:30PM |
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 04:08AM |
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 07:29AM |
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 09:06AM |
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 09:09AM |
Kasahabo
Hello
I have recently purchased a Cube Pro Duo for $200 plus shipping it is non working condition. Assuming that the worst thing would be a burnt up control board. Its condition doesn't bother me as I am prepared to learn and will be replacing it anyway. Hopefully it will be here in a week. I do have a few questions before getting started with the build but first a question about proper forum etiquette. Would it be be the right thing to do to post questions under this thread or start a new thread under the General heading category. I do not wish to wish to distract others from this one.
Thank you for your help.
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 09:18AM |
Decay There are three settings that are controlled on the TMC2100 by the decay mode or rather "chopper configuration": CFG0, CFG4 and CFG5 in the TMC2100 data sheet. CFG0: Sets chopper off time (Duration of slow decay phase) DIS - 140 Tclk (recommended, most universal choice) EN - 236 Tclk (medium) CFG4: Sets chopper hysteresis (Tuning of zero crossing precision) DIS: (recommended most universal choice): low hysteresis with ≈4% of full scale current. EN: high setting with ≈6% of full scale current at sense resistor. CFG5: Sets chopper blank time ( Duration of blanking of switching spike ) Blank time (in number of clock cycles) DIS - 16 (best performance for stealthChop) EN - 24 (recommended, most universal choice) 0 - DIS_CFG0 | DIS_CFG4 | DIS_CFG5 1 - DIS_CFG0 | DIS_CFG4 | EN_CFG5 2 - DIS_CFG0 | EN_CFG4 | DIS_CFG5 3 - DIS_CFG0 | EN_CFG4 | EN_CFG5 4 - EN_CFG0 | DIS_CFG4 | DIS_CFG5 5 - EN_CFG0 | DIS_CFG4 | EN_CFG5 6 - EN_CFG0 | EN_CFG4 | DIS_CFG5 7 - EN_CFG0 | EN_CFG4 | EN_CFG5 Microstepping 0 - Full step 1 - Half step 2 - Half step, interpolated to 256 3 - Quarter step 4 - 16th step 5 - Quarter step, interpolated to 256 microsteps 6 - 16th step, interpolated to 256 microsteps 7 - Quarter step, StealthChop, interpolated to 256 microsteps 8 - 16th step, StealthChop, interpolated to 256 microsteps
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 09:24AM |
Kasahabo
Hello
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 09:34AM |
obelisk79
I decided to make my conversion as cheap as possible so I decided on going with a RAMPS board and DRV8825's.
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 09:51AM |
Re: An alternative to buying a bad kit for $300-500 October 31, 2016 10:00AM |
the_digital_dentist
obelisk79
You may have problems with those drivers. They don't microstep well at low speeds with low voltage motors. See: [cabristor.blogspot.com.by]
Re: An alternative to buying a bad kit for $300-500 November 01, 2016 04:09AM |
Re: An alternative to buying a bad kit for $300-500 November 01, 2016 04:19AM |
Re: An alternative to buying a bad kit for $300-500 November 01, 2016 08:29AM |
Kasahabo
Thank you for your offer of the control board Dancook. I will keep that in mind.
Re: An alternative to buying a bad kit for $300-500 November 01, 2016 02:52PM |
Re: An alternative to buying a bad kit for $300-500 November 02, 2016 04:39AM |
Re: An alternative to buying a bad kit for $300-500 November 03, 2016 01:02AM |
Re: An alternative to buying a bad kit for $300-500 November 03, 2016 05:27AM |
Re: An alternative to buying a bad kit for $300-500 November 03, 2016 07:34PM |
Re: An alternative to buying a bad kit for $300-500 November 03, 2016 07:39PM |
Re: An alternative to buying a bad kit for $300-500 November 03, 2016 08:33PM |
Re: An alternative to buying a bad kit for $300-500 November 03, 2016 08:40PM |
Re: An alternative to buying a bad kit for $300-500 November 04, 2016 12:21AM |
Re: An alternative to buying a bad kit for $300-500 November 05, 2016 02:21PM |
