Re: An alternative to buying a bad kit for $300-500 November 07, 2016 08:56AM |
Re: An alternative to buying a bad kit for $300-500 November 07, 2016 03:48PM |
Re: An alternative to buying a bad kit for $300-500 November 07, 2016 03:55PM |
Re: An alternative to buying a bad kit for $300-500 November 07, 2016 03:57PM |
Re: An alternative to buying a bad kit for $300-500 November 07, 2016 03:58PM |
Dancook
I have my Cubex roughly put together. I printed a test cube over the weekend, but my Bowden extruder and the knock off chimera hot end just weren't performing. I ordered an E3D Titan and v6 hot end, and they should be here today or tomorrow. I wanted to do Bowden, but I'll probably be printing with Ninjaflex more than anything.
Re: An alternative to buying a bad kit for $300-500 November 07, 2016 05:19PM |
Re: An alternative to buying a bad kit for $300-500 November 07, 2016 05:34PM |
Re: An alternative to buying a bad kit for $300-500 November 07, 2016 06:10PM |
PDBeal
Even trying to print 1.75 Ninjaflex with the Titan E3D with the tension screw backed off to nothing at 5mm/s wouldn't take enough filament while trying to do the 100mm calibration, and then slowly giving it 1/4 turns it would then start sticking to the idler and making its way outside the captured path. I managed to create some Ninjaflex parts, but I highly doubt they were not underextruded based on the attempts I had trying to calibrate the Titan E3D extruder with 1.75 Ninjaflex filament. From what I've seen and read, Ninjaflex 3mm works with the first tension setting, but 1.75 is a crap shoot if you can get it working reliably and consistent at all with the Titan.
Re: An alternative to buying a bad kit for $300-500 November 07, 2016 08:39PM |
Re: An alternative to buying a bad kit for $300-500 November 08, 2016 08:19AM |
Re: An alternative to buying a bad kit for $300-500 November 08, 2016 10:07AM |
Re: An alternative to buying a bad kit for $300-500 November 08, 2016 01:05PM |
Re: An alternative to buying a bad kit for $300-500 November 10, 2016 02:45PM |
Re: An alternative to buying a bad kit for $300-500 November 10, 2016 04:01PM |
Re: An alternative to buying a bad kit for $300-500 November 11, 2016 09:12AM |
Re: An alternative to buying a bad kit for $300-500 November 11, 2016 10:18AM |
Re: An alternative to buying a bad kit for $300-500 November 11, 2016 12:11PM |
Re: An alternative to buying a bad kit for $300-500 November 11, 2016 02:56PM |
Re: An alternative to buying a bad kit for $300-500 November 15, 2016 07:55PM |
Re: An alternative to buying a bad kit for $300-500 November 16, 2016 07:30AM |
DaGameFace
What voltage should you use for drv8825s? Mine are getting really hot quite quickly, tried an a4988 as well with same result..
edit: around .6 V is the lowest I can go and still move my Z axis, turns out it does not get hot at this temp, I had mistaken which way to turn the pot. to decrease voltage
Re: An alternative to buying a bad kit for $300-500 November 16, 2016 08:19PM |
Re: An alternative to buying a bad kit for $300-500 November 17, 2016 08:10PM |
Re: An alternative to buying a bad kit for $300-500 November 18, 2016 11:14AM |
Re: An alternative to buying a bad kit for $300-500 November 18, 2016 02:42PM |
Re: An alternative to buying a bad kit for $300-500 November 18, 2016 02:47PM |
Re: An alternative to buying a bad kit for $300-500 November 18, 2016 02:58PM |
Re: An alternative to buying a bad kit for $300-500 November 18, 2016 05:14PM |
Re: An alternative to buying a bad kit for $300-500 November 18, 2016 05:37PM |
Re: An alternative to buying a bad kit for $300-500 November 18, 2016 06:04PM |
Re: An alternative to buying a bad kit for $300-500 November 18, 2016 06:13PM |
