Re: An alternative to buying a bad kit for $300-500 March 26, 2018 12:06PM |
Re: An alternative to buying a bad kit for $300-500 March 27, 2018 11:32AM |
Re: An alternative to buying a bad kit for $300-500 March 28, 2018 08:42AM |
Re: An alternative to buying a bad kit for $300-500 April 15, 2018 05:49PM |
Re: An alternative to buying a bad kit for $300-500 April 15, 2018 07:16PM |
Re: An alternative to buying a bad kit for $300-500 April 21, 2018 01:25PM |
Re: An alternative to buying a bad kit for $300-500 April 25, 2018 02:35PM |
Re: An alternative to buying a bad kit for $300-500 April 25, 2018 02:37PM |
Re: An alternative to buying a bad kit for $300-500 April 25, 2018 02:39PM |
Re: An alternative to buying a bad kit for $300-500 April 26, 2018 03:37AM |
Re: An alternative to buying a bad kit for $300-500 May 06, 2018 03:09PM |
Re: An alternative to buying a bad kit for $300-500 November 06, 2018 07:06PM |
Re: An alternative to buying a bad kit for $300-500 December 03, 2018 10:11AM |
Re: An alternative to buying a bad kit for $300-500 December 03, 2018 02:28PM |
Re: An alternative to buying a bad kit for $300-500 December 03, 2018 02:39PM |
First issue is 12v or 24v power supply.
Re: An alternative to buying a bad kit for $300-500 December 03, 2018 03:17PM |
jimboh3
I am new to 3D printing and just scored a pair of Duo's for $250CAD. One works fine and has been modded by previous owner to take std 1.75 filament. The other has a problem with electronics. My intention is to Reprap this one and use the other to build any parts i need for it.
I decided not to go the 32bit route as, at the moment I feel it would be overkill. I have on order a Rumba clone (Tango v1) with smart controller lcd and have prepped a Pi B+ I had laying around (from a Brewpi project) with Octopi and Octoprint.
Re: An alternative to buying a bad kit for $300-500 December 03, 2018 04:09PM |
Re: An alternative to buying a bad kit for $300-500 December 05, 2018 11:23AM |
Re: An alternative to buying a bad kit for $300-500 December 05, 2018 12:01PM |
Re: An alternative to buying a bad kit for $300-500 December 05, 2018 12:36PM |
Re: An alternative to buying a bad kit for $300-500 December 05, 2018 03:44PM |
Firefox3D
The print head heaters do need 15V to operate properly. I tried a Cubepro head which I am guessing runs at 24V as the higher resistance heater wire meant the Duet would think there was a fault as it couldn't heat it fast enough.
Re: An alternative to buying a bad kit for $300-500 December 07, 2018 10:09AM |
Re: An alternative to buying a bad kit for $300-500 December 07, 2018 06:07PM |
Re: An alternative to buying a bad kit for $300-500 December 07, 2018 07:01PM |
Re: An alternative to buying a bad kit for $300-500 December 07, 2018 08:26PM |
Dancook
Thanks, Firefox3D... I literally beat my head up against the wall trying to figure out how to print without the rounding errors... I ordered one of the stepper/lead screw combos as you mentioned... it'll be here tomorrow, so hopefully I'll get perfect prints tomorrow. Did you get a NEMA 17 version? I didn't see any NEMA 23 versions.
Re: An alternative to buying a bad kit for $300-500 December 07, 2018 08:32PM |
dc42
Firefox3D
Did you run heater tuning? On the Duet, heater tuning not only allows good PID parameters to be calculated, it also calibrates what the firmware considers normal behaviour for the heater, which affects the heater fault detection.
Re: An alternative to buying a bad kit for $300-500 December 08, 2018 02:58AM |
Firefox3D
I was trying the other head as I thought I had a fault with the original one, turned out just to be a half broken wire near one of the crimps. The resistance of the Cubex heater is 5 ohms which seems to be in the normal range, the Cubepro head is nearer to 10 ohms, is this within tunable range?
Re: An alternative to buying a bad kit for $300-500 December 08, 2018 09:45AM |
dc42
Firefox3D
If you were running a 10 ohm heater at 12V then it would probably not be able to maintain printing temperature. At 15V it would probably be OK, at least for the temperatures needed to print PLA.
Re: An alternative to buying a bad kit for $300-500 December 18, 2018 01:34AM |
Re: An alternative to buying a bad kit for $300-500 January 31, 2019 09:09AM |
jason128
Quick question - does anyone know what voltage the led enclosure and hotend lights on a cube PRO run on? They have a resistor wired in to them, I have tried the. On 12v but they seem too bright-I’m concerned they will be cooked if I run them at this voltage.
I’m . In the process of installing a panel duet to a cube pro trio
