Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 07:03AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 07:04AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 09:05AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 09:51AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 03:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 03:40PM |
Captain_Tim
Watching that video, he says that his ESteps are 900 by default, mine is 370. Now I know that just because his is 900 doesn't mean mine will be there, but 370 does seem very low. I would do a lot more testing, but this extruder gear will just not grip on the filament. It just grinds it up. I'll try to reposition it again, but I'm also going to buy a new gear.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 03:42PM |
spiffcow
Captain_Tim
What units are those in? 125 steps/mm was right for me (250 now that I switched DRV8825 drivers). 370 is just going to grind your filament to dust
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 03:58PM |
Captain_Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 04:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 04:55PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 04:58PM |
EvilBetty
Does anyone here have any luck getting their bed above 110 deg C?
I can get to 70 really quick. 110 after about 5-10 minutes with a room temp of about 68-70. But haven't yet been able to reach 115 deg C. I'm setup in the basement so I'm wondering if I'm fighting against my ambient room temp.
(Rel humidity about 35%)
-EB
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 05:05PM |
EvilBetty
-EB
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 05:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 05:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 06:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 06:46PM |
paul_delta
PPS: if you need so hot bed because of ABS warping - i'd say that ambient 68F is too cold for ABS. You may try to build a wall around your printer to reduce airflow.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 11:20PM |
EvilBetty
paul_delta
Yeah I figured that. Enclosing the printer isn't really practical at the moment. If I consider that later, I'm going to build a complete raised wooden / plexi enclosure, similar to the base on a ROSTOCK MAX V2, to put the Raspberry Pi and Power supply inside of, and build 2 side and a door out of the plexi. May have to wait until next winter though.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 11:24PM |
Captain_Tim
When using dc42's calculator, which EEPROM setting gets modified for the "tower position angle corrections"? Is it Alpha A/B/C, Delta Radius A/B/C, or something different?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 11:26PM |
Captain_Tim
On DC42's calculator, is "tower angular position" the Alpha values? So 210, 330, and 90? And to add the adjustments, I subtract the suggested values from that? So a correction of -1.3 for X would be 210 - 1.3 = 208.7 as the new Alpha A value? Just want to double check as I can't seem to get it quite dialed in.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 11:30PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 20, 2016 11:35PM |
Captain_Tim
EvilBetty
paul_delta
You could create a quick enclosure using some sheets of wood, or even cardboard might work. If it helps keep the heat in, any bit will help.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 21, 2016 11:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 21, 2016 01:33PM |
Captain_Tim
Printed out another calibration cube with the extruder now calibrated, ran through the calculator a few times, turned on Spiral vase mode for this print, added 0.5mm for a Z-Offset in Slic3r, and the results, in my opinion, were amazing! X and Y are about .3mm longer, Z is about .1mm to high, and the perimeters are 0.43mm, which according to the GCode, should be 0.48mm, but that's pretty darn close. Pictures below (This is the nicest print I've ever had, even on my Two Up when it was functional)
Still on the Bed
Without Flash
With Flash
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 21, 2016 01:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 21, 2016 01:49PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 22, 2016 05:22AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 23, 2016 12:43AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 23, 2016 06:00AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 23, 2016 08:47PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 23, 2016 08:50PM |
Captain_Tim
Over the past few days, I've been printing on my Kossel, some calibration cubes, as well as a fan shroud (Thanks Paul_Delta), and a dampening foot (I still need to print 5 more). I turned it on today, loaded a file to print into Repetier, sliced it, and hit print. The bed started to heat up, and it reached it's 60 degree mark. It went to home, and this is where something odd happened. Both the Y and Z axis go to home, but X doesn't move. If I manually move it in Repetier along the Z axis, they all move, both up and down, but selecting home, the X motor does not move. The only difference between yesterday and today is some slicer settings. Any ideas?
