Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 01, 2016 07:24AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 01, 2016 01:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 01, 2016 09:56PM |
spiffcow
So last night I finally got a perfect delta calibration print (this one [www.thingiverse.com]). I'm pretty psyched, but I notice my prints are still not as smooth as I would like. And by that I mean that they have a physically rough texture. I'm wondering if this is due to the jiggle of the traxxas connectors and the error in length between them, and was considering getting a set of preassembled magnetic arms. Has anyone gone this route? Have you gotten better prints from magnetic arms? Anyone tried it and regretted it?
Also, can anyone recommend bridging settings? Somewhere along the way I must have screwed mine up, as the hollow cube that printed great on my first try is no longer bridging properly.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 01, 2016 09:58PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 01, 2016 11:05PM |
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 01, 2016 11:52PM |
paul_delta
PS: try to print something in vase mode (spiral, single wall) - is the external surface acceptable in this case?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 02, 2016 01:52PM |
spiffcow
paul_delta
Here's one pic.. I'm in the middle of a long print job, but I'll try vase mode when its done. The fan in the pic isn't in vase mode, but i'm pretty happy with how it came out. The cube just didn't bridge at all though, and the tops of things are really rough if they have infill underneath. Also, the infill looks messy during prints.
EDIT
I printed a decent sized object at 0.1mm and got amazingly smooth results. So I think I'm done calibrating
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 02, 2016 02:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 02, 2016 02:47PM |
docpayce
@spiffcow: Amazing result! Looks very smooth. If you still want to reduce Traxxas joint jiggle - use springs close to the traxxas joints to pull the rods towards each other *slightly* - just enough to get rid of the jiggle, not so much as to deform the rods. That was one of the very first mods I made - though I dont know the impact. A nice set of springs is like 15 bucks (http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20160302112653&SearchText=spring).
I dont have magnet rods yet, but I am reaaaally thinking about that mod. Wouldn't be to hard. I already have the rods - I would just need to add magnets (4 bucks) and steel balls (1 buck). I do think I'll do that.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 02, 2016 05:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 02, 2016 06:02PM |
Captain_Tim
What could cause these layer gaps?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 02, 2016 06:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 12:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 01:13PM |
foryst
Fun fact! The revision of Marlin that FoglerTech has in their file store isn't actually based on a full-spec Marlin 1.0.x, and so DC42's site will help to calculate the smooth rod length, but not the endstop offset, since the M665 and M666 commands are literally not in the code base of that repo (okay, DC42's site will technically still calculate it, but you won't be able to do anything with them without moving to newer firmware).
Anyhow, after finally fixing some issues with my hot end and getting as much mechanically tuned as I can, I've moved onto some mid-scale prints that print wonderfully for the first 1.5-2 cms, and them go crap (notably, a 50% scale verison of [www.thingiverse.com]). I finally diagnosed that at about that point, height wise, the head seems to be dragging over the previous layers for a couple slices, getting out of whack, until the origin is out of sync and then it starts printing normally again just shifted off center, producing some unintended real-world glitch art.
My best bet right now is that the motors / stepper boards are overheating and skipping steps, so I'd love to know what others are using for Vref if using a standard FT RevB kit. However, my other question is, if I am in fact getting steps skipped, wouldn't I expect to see it in artifacts in all three dimensions, and not just a compression of the Z-dimension?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 04:18PM |
foryst
Very distinct and fear-inducing noise.|
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 04:30PM |
foryst
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 05:05PM |
docpayce
I went as far as to look at the resitors on the driver boards with a microscope to check the values. *If* you received the same drivers (I would bet), the exact voltages are 0.32 V for the small NEMA17's (gives 0.4 amps) and 0.64ish for the big extruder one (0.8A - can go to 1.2A if you want to).
Note that the print you are aiming for is reaaaally hard to do, especially at 50% scale. The small overhanging parts tend to stick up a bit (if not cooled VERY efficiently) and get stuck on the printhead moving by on the next layer. (... ... that was a little bit hard to understand I fear. Did you get me?)
First thing I would do is get an easier model and check whether you run into problems there, too.
You have some photo of the print?
Also, if you had missed steps ... you would HEAR that.Very distinct and fear-inducing noise.
Another possibility (not likely tho): Are all GT2 belts at approximately the same tension?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 05:31PM |
foryst
docpayce
Thanks for the driver readings. I'm pretty sure that that cements that I'm at least running hot, in addition to possible other things. As for the print, it certainly is a more complex one than some of the others I've done. My most successful/complex print was another reduced scale one of these (https://www.thingiverse.com/thing:1087797) which printed mostly accurately, in addition to a number of progressively better calibration cubes.
I haven't heard any crazy noises that would sound like missed steps, but I will admit one of my belts is noticeably tighter than the others, from some post-build tweaks involving better leveling of the top triangle. If the motor tuning and further tuning of extrusion amount as suggested by paul_delta doesn't work, I'll try loosening that belt by a tooth or two.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 09:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 10:07PM |
Gingerbreadman
Z-probe offset. I printed paul_deltas magnet z probe carriage for the rev. B kossel. I tried different settings in the following configuration.h file to input the new offsets without success, just alot of aborted bed crashes of my new sensor mount. The current and original restored settings are below.
#define Z_PROBE_OFFSET {0,0-.6,0} // (0,14, -6.5,0) {24.6,-21,0,0} {24.6,-21,0,0} X, Y, Z, E distance between hotend nozzle and deployed bed leveling probe. (0,19-8,0)
So, am I even on the right track?
On a side note to paul_delta your magnetic couplings are a god send , in that they are almost idiot proof. They gave way and protected my mechanicals on each of my aborted autoleveling attempts!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 10:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 04, 2016 10:59PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 05, 2016 01:46PM |
Gingerbreadman
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 05, 2016 02:03PM |
Gingerbreadman
Marlin firmware’s Configuration.h, last attempt update, I changed from the folger tech default settings in "Z_probe offset" to {0,0,-69.4,0} based on info from a m114 command. When I run a g29 it attempts to plow through the bed.
Gingerbreadman
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 05, 2016 02:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 05, 2016 05:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 05, 2016 06:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 05, 2016 06:17PM |
PrimeraRata
Can i simple migrate my actual marlin configuration.h to reptier or need to see something?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 05, 2016 07:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 06, 2016 04:14PM |
