Re: Laser cut Aluminium X-Arm & Rib kits.... June 05, 2015 12:11PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 05, 2015 01:53PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 05, 2015 02:07PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 08:45AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 08:53AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 09:50AM |
;G30 P0 X60 Y20 Z-0.039 ;G30 P1 X60 Y180 Z0.447 ;G30 P2 X180 Y180 Z2.947 ;G30 P3 X180 Y20 Z2.845 S
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 12:33PM |
Treito
...I am not able to level the bed fully. In comparison with the documentation from Ormerod MK2 I get level points B+C 5.9mm distance and A 5.8mm. The screws at B+c are at the end and the PCB is even slightly bended at point A so I do not want to exchange the other screws. I hope that this slightly difference will work.
The cause is the MDF. From the beginning there was something wrong. regarding to the beginning this is a very good result as you can see here:
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 01:34PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 01:48PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 01:58PM |
Treito
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 02:20PM |
dc42
[You mean you are still using the original MDF bed support? That's the first thing you need to change!
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 04:39PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 07, 2015 04:57PM |
dc42
It's not MDF that connects the bed support to the rod, it's a plywood rib, and that is usually stable enough. But if the front of the bed is too high, check that it is sitting on the front linear bearing properly.
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 01:55PM |
19:29:05 G32 Bed equation fits points [50.0, 30.0, 0.215] [50.0, 190.0, 0.243] [180.0, 190.0, 0.232] [180.0, 30.0, 0.225] 19:28:22 G32 Bed equation fits points [50.0, 30.0, 0.204] [50.0, 190.0, 0.237] [180.0, 190.0, 0.209] [180.0, 30.0, 0.244]
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 02:14PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 02:21PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 02:48PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 02:52PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 03:00PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 03:04PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 03:12PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 03:20PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 03:47PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 08, 2015 03:51PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 10, 2015 06:36AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 15, 2015 08:15AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 16, 2015 05:14PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 17, 2015 07:17PM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 18, 2015 01:50AM |
Re: Laser cut Aluminium X-Arm & Rib kits.... June 19, 2015 06:46AM |
