Re: Folger Prusa i3 Kit from ebay January 10, 2015 02:14PM |
Re: Folger Prusa i3 Kit from ebay January 10, 2015 05:19PM |
Re: Folger Prusa i3 Kit from ebay January 10, 2015 05:25PM |
Re: Folger Prusa i3 Kit from ebay January 10, 2015 05:46PM |
Re: Folger Prusa i3 Kit from ebay January 10, 2015 05:50PM |
See the github link vonnieda linked back on page 29 of this thread. Has a link to Waltermixx's and Doom101's configuration.h files.Quote
HairLikeFrodo
If you guys wouldn't mind I've been having some trouble getting the config right, would you be able to post your configuration.h files so I can compare?
Re: Folger Prusa i3 Kit from ebay January 10, 2015 08:33PM |
Re: Folger Prusa i3 Kit from ebay January 11, 2015 02:16PM |
Re: Folger Prusa i3 Kit from ebay January 11, 2015 04:11PM |
Re: Folger Prusa i3 Kit from ebay January 11, 2015 04:19PM |
Re: Folger Prusa i3 Kit from ebay January 11, 2015 08:51PM |
Re: Folger Prusa i3 Kit from ebay January 12, 2015 09:35AM |
This crossed my mind last night too, I get some not-too-pleasant sounds coming from the X and Y axis bearings from time to time, but it still seems to be running smoothlyQuote
xhamburglarx
Do the linear bearings need some sort of lubrication? I seem to have a rattle coming from the X Axis bearings.
Re: Folger Prusa i3 Kit from ebay January 12, 2015 03:16PM |
Re: Folger Prusa i3 Kit from ebay January 12, 2015 06:54PM |
Re: Folger Prusa i3 Kit from ebay January 12, 2015 09:05PM |
JSR82
I just finished building my kit today. I couldn't figure out a better way to mount the Y endstop. So, I put it at the back right corner which seemed like the best place for it so as not to lose build volume. The problem I am having with the printer is when I try to manually home the Y axis it moves a tiny bit towards the back but never goes farther than that. I am using the files on Folger Tech's google drive and I've edited the configuration.h file so that...
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
#define Z_HOME_DIR -1
This fixed the problem of the bed moving in the wrong direction when I try to manually home as per the instructions on their google drive.
Is there another setting I need to change?
Re: Folger Prusa i3 Kit from ebay January 13, 2015 12:35AM |
Re: Folger Prusa i3 Kit from ebay January 13, 2015 03:16AM |
Re: Folger Prusa i3 Kit from ebay January 13, 2015 10:13AM |
Re: Folger Prusa i3 Kit from ebay January 13, 2015 11:19AM |
MindRealm
Disconnect the heated bed from the RAMPS and test the wires going to the bed for resistance. This will ensure that you are not wasting your time trying to get a bad bed working. Post your findings and we'll go from there.
Re: Folger Prusa i3 Kit from ebay January 13, 2015 03:05PM |
Re: Folger Prusa i3 Kit from ebay January 13, 2015 04:11PM |
Re: Folger Prusa i3 Kit from ebay January 13, 2015 05:53PM |
Mine did the same thing. I probably should have been more concerned about it, but I just let it continue heating up, and after 10-15 seconds in quit smoking. I'm guessing it's some something on the nozzle that burns off.Quote
ErraticDecay
Greetings everyone,
I've been lurking here for quite awhile until my printer arrived, which it did yesterday. It's now built (quite a bit of cleanup on wires to do yet) however, I just used pronterface to manually head both the bed and hotend to validate they're working. Set the hotend to 185 (pronterface's recommendation for PLA) and after about 15-20 seconts @ what appeared to be 141 degrees the end started smoking. I immediately shut it off in fears of ruining something. Is there grease or something from factory that burns off initially or is there an issue?.
Re: Folger Prusa i3 Kit from ebay January 14, 2015 12:18AM |
Re: Folger Prusa i3 Kit from ebay January 14, 2015 01:37AM |
boy09
Re: Folger Prusa i3 Kit from ebay January 14, 2015 02:45AM |
jrcaster
Still not getting good prints. The extruder is ticking and each time the filament jumps up a little. With PLA it causes thin extrusion that doesn't adhere properly. With ABS it still does it but not as bad. Using ABS I can hold a little pressure on the filament and get it to complete the print. It seems like it doesn't have enough clamping presure from the V grooved bearing. Is there any way to fix this?
Re: Folger Prusa i3 Kit from ebay January 14, 2015 05:21AM |
The ticking have nothing to do with the bearing pressure. Too much pressure from the bearing can make it ticking too. Ticking means the force needed to feed the filament exceeds motor's power. There's many possible causes for that, both can be present, alone or at the same time. Maybe the stepstick is not set properly (less or too much current). Maybe the stepper motor is damaged (I had my folger's extruder motor dead within 250 hours. Small and cheap motors are fragile.) Check it's operational temperature, remember the heatsink block is directly screwed on it ! Maybe it's a hotend problem. Clogging makes the filament hard to be pushed, try machine off and extruder hot. You should push the filament without any noticeable resistance. Keep in mind that your cold end temperature may change during print time, as far Folger's system have some trouble to keep the coldend cold ! A good fand can helps a lot : 40mm fans @$1.50 on ebay have two times more power than Folger's. Last, check that nothings obturate the nozzle. Some filaments carries sand or metal chips that stands in the nozzle. Some lucky people do, but I never managed to print properly with Folger's extruder, and replaced it all : new motor, new extruder (using Folger's gear and bearing), new hotend (E3D V5). And now I can use my printer and print with confidence.Quote
jrcaster
Re: Folger Prusa i3 Kit from ebay January 14, 2015 05:18PM |
Re: Folger Prusa i3 Kit from ebay January 14, 2015 07:09PM |
Re: Folger Prusa i3 Kit from ebay January 14, 2015 08:33PM |
Re: Folger Prusa i3 Kit from ebay January 14, 2015 09:07PM |
Re: Folger Prusa i3 Kit from ebay January 15, 2015 12:41AM |
