Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 10, 2015 09:24AM |
msaeger
[The E3D Lite6 I upgraded to does not leak at all not yet anyway It actually will start putting down material right when the print starts because it all didn't leak out while heating up like the Folger one would. Defiantly was a good upgrade.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 10, 2015 11:58AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 10, 2015 12:11PM |
TollBoothWilly
msaeger
What modifications are required to switch over to this hot end?
Does the extra length of the heat sink take away from the vertical printing area?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 10, 2015 01:59PM |
Yelloow-Snow
So.... what a night.
[imgur.com]
I made it all pretty to only plug it back in and 1 Z motor not work. Ordered new parts only to wake up and check the wires on the cable were cut. All fixed.
Auto leveling question.
My bed is 220 x 220 b/c i can use the full bed. (No glass)
I run G0 X0 Y0. I then run G29 for auto leveling. Then sensor goes straight down no matter what I put in
#define LEFT_PROBE_BED_POSITION 33
If I run G28 the sensor is in the middle of the bed. G29 after and it does not go to the corner.
Do you run X0 Y0 or G28 before G29?
hmmmm
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 10, 2015 06:21PM |
Yelloow-Snow
[imgur.com]
hmmmm
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 10, 2015 06:33PM |
Slaghton
Ah thanks, not sure how I missed those stl's. I downloaded some other batch. I saw your modification . I might have to look into it if it reduces vibration/increases print quality =).
P.S. For people talking about Y axis vibration sound. My plastic bearing holders having their screw holes getting stripped so the bed isn't fastened securely is causing a loud vibration sound. Printing 3 new ones since I can still print pretty good.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 10, 2015 06:37PM |
Slaghton
Here's my most recent print even with my heavy vibration for my bearing holders being loose.
(the band artifact was caused by me pressing my finger lightly against a rattling bearing)
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 10, 2015 07:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 11, 2015 06:08AM |
Uncertainty
I feel like I have my prints mirrored. My Y-endstop is a "max" and it is located at 200mm at the back of the printer.
I have found this drawing online, do people agree with this? [www.lincade.org]
Also could you post your lines from Configuration.h where the endstops, direction and invert are defined?
Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 11, 2015 04:20PM |
Uncertainty
Thanks
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 11, 2015 05:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 11, 2015 05:28PM |
therippa
Is anyone else starting to have problem printing now that the weather is getting colder? It doesn't get very cold in San Francisco, but my printer is right next to a window and I've been having warping/layer separation issues. It may be time to resurrect the idea of building an enclosure...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 11, 2015 05:31PM |
therippa
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 11, 2015 07:27PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 11, 2015 07:49PM |
animoose
therippa
Oddly enough, I have noticed this recently, though I also started a new roll of filament which seems to have some different characteristics to the previous one. I'm in LA and we're definitely starting to feel the brutal Southern California winter kicking in this week.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 11, 2015 11:01PM |
Smuggler17
Uncertainty
Thanks
If your Y endstop is at the back of your kit then it is in the "min" position. This is because the software is using the position of the hot end as it's reference, not the position of the bed itself (aka moving the bed to the back of the frame brings the hot end to the front of the print area or the min position in this case).
Change your configuration.h file to match below and see if it fixes the mirroring issue:
#define INVERT_Y_DIR true
#define Y_HOME_DIR -1
Also, make sure that your Y endstop is plugged into the correct set of pins for the min position (5th from the left)
In Repetier set your Y home position as min
If your prints are still mirrored after making that change then it is likely the X axis that is inverted. In this case make the following changes:
#define INVERT_X_DIR false
#define X_HOME_DIR 1
Connect the X endstop to the pins for max position (6th from the left)
In Repetier set you X home position as max
I had an issue with inverted prints and the above setup took care of it for me, so let me know if it doesn't work
Edited because I should probably read the post directly above mine before replying (sorry for the duplicate Sonnylowe)
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 10:35AM |
Uncertainty
Smuggler17
Uncertainty
Thanks
Thank you Smuggler17 & sonnylowe
My problem was that I was so focused on the software that I forgot to change the connector on the RAMPS board lol...
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 10:45AM |
Yelloow-Snow
therippa
Nope tho its still warm in Louisiana. that and my large reef tank in the room keeps it hot.
Maybe PID Tuning again when the weather changes?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 11:57AM |
msaeger
Yelloow-Snow
therippa
That was a good idea my stuff wasn't sticking as good so I ran auto tune on the bed again and it's sticking much better.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 12:40PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 12:57PM |
Yelloow-Snow
msaeger
Yelloow-Snow
therippa
Awesome! Maybe run it on the extruder also? :: shrug :: I'm still a noob.
I ordered a new hot end. Going to do Bowden but i want to do something different. I want to mount the extruder right above the hot end on the top rail. Reduce the distance and keep the weight low on the X axis. It will feed it straight down.
hmmm Why hasent anyone else done this?
Also... after hours and hours of work here is my S3D starting script.
I unchecked "Wait for temp to stablize before beginning build" This allows me to auto level with 16 points while the bed is heating up.
Also things to note: I disabled the checkbox "Relative extrusion distances" and "Update firmware configuration"
Still confused why I have to G92 after G29. At the end of G29 it says X is -36 which is the distance of the probe.
G21 ; Units to mm
G90 ; Absolute positioning
M82 ; Use absolute distances for extruder
G92 E0 ; Zero the extruder position
G28 ; Center all Axis
G0 X0 Y13 ; Move to start of auto leveling
G29 ; Auto Leveling
G92 X0 Y210 ;Set the extruder to the actually coordinates. Back left.
M105 ; Read current temp
M190 S110 ; Set bed temp and wait to be reached
M109 S230 ; Set extruder temp and wait to be reached
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 01:02PM |
sonnylowe
Yelloow-Snow
msaeger
Yelloow-Snow
therippa
G21 ; Units to mm
G29 ; Auto Leveling
Thanks for the S3D info, I am about to make that purchase so any and all advice is welcome :-)
As far as the Bowden directly above the hotend on the rail, I've actually thought of that as well, but I'm not sure it will work. It works with the filament roll there because the filament can lengthen and shorten as the X-Axis raises and the hotend move left to right. The Bowden tube will not do that and would most likely bind as the X-Axis moves. Maybe if you built a loop into the tube it would allow for the flexibility required to move with the X carriage, but that seems to defeat the purpose of that location!?!?
I'd like to hear more about this...like I said, I thought about it but quickly dismissed it...
Sonny
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 01:07PM |
Yelloow-Snow
sonnylowe
Yelloow-Snow
msaeger
Yelloow-Snow
therippa
G21 ; Units to mm
G29 ; Auto Leveling
Sonny
I have been told to check out Meshmixer and Mattercontrol. Those 2 combined can work just as good as S3D. Thats just what I was told. Might as well check it out b/c its free.
Also S3D allows you to install it on 2 computers so you can find someone to split the cost. My dad bought it so I used his other licenses.
There are still a few features in S3D I wish it had. Its ok to me. Sure everyone says it slices perfectly and fast but im a noob and haven't really tested it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 01:48PM |
Yelloow-Snow
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 02:24PM |
therippa
Yelloow-Snow
You want the bowden cable to be long enough to comfortable flex as it goes side-to-side. I think mounting it on the top rail would cause feeding/buckling issues.
...and I like this temp stabilization change you've made, but my immediate though would be that the bed expands a little heating up, so the autolevel might be a little off by the time it's ready to go.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 02:46PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 07:36PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 09:47PM |
Yelloow-Snow
msaeger
Yelloow-Snow
therippa
G21 ; Units to mm
G29 ; Auto Leveling
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 10:26PM |
msaeger
I got that aluminum bed plate like you have in the pictures but haven't installed it yet. Are you putting anything on it to get the print to stick? I was planning to still have the glass on there because I am thinking it would be hard to clean the glue or whatever off with it attached to the printer.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 12, 2015 10:49PM |
Yelloow-Snow
msaeger
Glass is best if you dont have an inductive sensor. If you use the sensor for auto leveling you cant use glass.
I use gluestick. I don't wipe it off. it sticks so crazy I have issues removing it.
