Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 16, 2016 10:58PM |
msaeger
[www.thingiverse.com] with a belt instead of the gears.
If you don't want to try and build it from scratch this guy is selling it ready to go. I bought a different design from him and it was good. [www.ebay.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 02:28AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 06:07AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 08:13AM |
marc2912
flatlander
marc2912
I noticed someone else mention it on here. I have an E3D with the stock extruder. I had to remove the aluminum block that sits under the extruder that the heat block screws into. I was going to upgrade my extruder to this from ebay but the block isn't removable and I won't be able to attach the hotend. What are people running with an E3D that is NOT a bowden extruder.
I purchased this on a recommendation from our Folger Tech thread here. I ran into the same problem, the hotend tube does screw into the bottom of this device and it probably would feed filament into the hotend. There were threads on the in-feed;I would drill out and the countersink that hole.It looked like it could transfer heat to the extruder stepper. It's for another day when I feel more adventurous. It's buyers remorse with a lowercase b. I did print out the instructions and folded them into the box.
It does say this, "Reduce the wiredrawing problem when working for remote feeding." Now that would make sense if it was a welder, but I'm not feeding any wire into my 3d printer.
Thanks with a stock hot end with an e3d it's even more pain as I'd have to mill part of the lower section away and find a way to fasten the hot end. Obviously not happening hence why I'm looking for people direct feeding e3d.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 08:27AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 08:51AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 10:48AM |
Bert3D
msaeger
Doesn't that extruder design cut off some of the vertical print height?
It would seem better to have the motor off to one side or to the front.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 11:56AM |
flatlander
Mine came with threads on top not the fine little hole you have...hence the need for a fitting up top.
[attachment 74765 AllMetalFeed72dpi.jpg]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 11:59AM |
jhitesma
flatlander
Yeah, that's a little different. Could probably print a little adapter to screw into that. Or use a bowden fitting, I'm guessing that's why it was designed like that so you could run a tube off either end.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 12:04PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 01:48PM |
UltiFix
Has anybody here upgraded to bowden? And is it worth it?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 01:53PM |
Toxic0n
How accurate are the printing estimations in Repetier/Slic3r?
When I was printing at 0.4 and 0.3mm layer height, I thought they were pretty close.
Printed these Z mounts at 0.2mm for the first time last night and the ETA said 2:44 and it took over 5 hours? 60mm/s printing speed. On the flip side, they look good!
[imgur.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 02:17PM |
UltiFix
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 02:37PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 03:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 03:06PM |
Toxic0n
[imgur.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 05:07PM |
iamquestar
UltiFix
I did. It was not worth it IMHO.
My goal was to lighten the hotend, to increase speed. I haven't been happy with some of the high speed tests I've done, so I'm still printing at the same rate. In addition, I had to mess with feed rate and retraction settings A LOT to get back to where I am reasonably happy with the results, however I had to drastically shorten the bowden tube before I was happy with how it was doing.
Initially I had the extruder mounted on the back of the frame, behind the left-hand upright. The tube ran out the back, then up and over the top bar to the hot end. Total length was probably around 60 cm or so. I could not get retraction settings dialed in with this. I think where was just too much slop introduced in that long of a tube.
I moved the extruder to the top bar, thereby cutting the length of tub to less than half of the original. This works MUCH BETTER. (I'll post a pic later when I get home) I am reasonably happy with the results, HOWEVER changing filament is a PITA.
All that being said, I am seriously considering going back to mounting the extruder to the X carriage. I did the v-slot upgrade, but got a bad gantry plate. The wheels don't tighten up all the way against the rail (just a little play, maybe .1mm). I contacted Open Builds and they admitted they had a bad batch of plates, with errors in the hole spacing. They are sending me a new one, so since I'll have to tear it all apart anyway, I think I'll be switching back at that time. I am thinking about going with one of the belted extruders, with a NEMA 14 motor to keep the weight down... But we'll see. I'm getting to the point where I want to stop messing with the printer, and just to be printing with it.
It's about time to move on to my next project: Either a CNC mini mill, or a laser engraver/cutter.
Honestly I guess I will just stick to direct for now... Im thinking of doing dual extruders, which I think would be a LOT of weight on the x axis... So maybe 1 bowden, and 1 direct drive.Quote
Mach
UltiFix
I upgraded to bowden and it work pretty well for me. Some people have mentioned that they do not like bowden because the retraction settings are difficult to perfect.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 17, 2016 05:34PM |
SteveRoy
From what I understand the slicers don't take acceleration/deceleration into account when estimating the times.
I usually use [gcode.ws] for a better estimate
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 12:37AM |
SteveRoy
Toxic0n
[imgur.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 08:33AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 09:32AM |
Boffster
Bookmarked! Thanks for the link!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 12:22PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 12:24PM |
jag
My FolgerTech 2020 i3 printer was working great except for 2 issues. Prints were 4% short on the Z-axis, and on some prints it was clear that filament volume was too low. I fixed both my changing DEFAULT_AXIS_STEPS_PER_UNIT in configuration.h
Here's my question: Why does the firmware on the FolgerTech Google drive have these settings: {80,80,3840,90} ? My printer works much better with what seems to be 'normal' settings {80,80,4000,100} for this printer design.
I have this resolved, just curious about the settings published on the Google Drive
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 12:34PM |
What about 90 vs 100Quote
marc2912
jag
It seems that FT had a bad value for the threaded rods hence the issue there, it's been a reoccurring topic on this thread. 4K is correct.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 12:50PM |
UltiFix
marc2912
jag
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 03:02PM |
jag
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 03:04PM |
marc2912
UltiFix
marc2912
jag
If you really tune everything the numbers won't be 80, 80 4000, 90 anyways, it could be he actually tuned his printer accordingly.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 03:09PM |
Bert3D
marc2912
UltiFix
marc2912
jag
Actually after tuning my extruder the E steps was 100.89, so it is pretty close to the calculated 100 steps. I'm not sure why 90 either.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 03:14PM |
So the last number (90) is the extrusion multiplier?Quote
marc2912
Bert3D
marc2912
UltiFix
marc2912
jag
I'm closer to 110 but I think my extruder gear has a low spot in and it skips a tiny bit every revolution. looking to change it out.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) March 18, 2016 03:25PM |
UltiFix
marc2912
Bert3D
marc2912
UltiFix
marc2912
jag
