Category:Development
Revision as of 07:40, 1 September 2016 by Lou (talk | contribs) (Full Kit Packing List)
About | Getting Started | RepRap Projects | Hardware | Software | Community
An Extruder Design on a Reprap Darwin
This page aims to contain links to all RepRap related development. This is the leading-edge and experimental part of the RepRap experience!
assembly instruction
  1. 01-A-9
  2. 02-B-6-1
  3. 03-B-7
  4. 04-B-5
  5. 05-B-4
  6. 06-B-6-3
  7. 07-B-6-2
  8. 08-B-2
  9. 09-B-3
  10. 10
  11. 11-B-4-1
  12. 12-B-4-2
  13. 13-B-7-1
  14. 14
  15. 15-A-6
  16. 16-A-10
Product Specifictions
Help and Support
A Fioor Gird Units
1 2040 Aiuminum Extrusion 420mm (2040型材 420mm) A-1 2 2 2040 Aiuminum Extrusion 400mm (2040型材 400mm) A-2 1 3 2020 Aiuminum Extrusion 400mm (2020型材 400mm) A-3 1 4 2020 Aiuminum Extrusion 380mm (2020型材 380mm) A-3 1 5 Threaded Rods 380m (丝杆 380mm) A-4 1 6 Aluminum Wires Holder (型材藏线管) A-4-1 3 7 2040 Aluminum Extrusion 150mm (2040型材 150mm) A-5 2 8 Acrylic For LCD Display (亚克力 -显示屏) A-6 2 9 2004 LCD Display (显示屏) A-6 1 10 screw Kits A-6 (螺丝包 -A6) A-6 1 11 Acrylic For L Alunimun Connector (压克力 - L型) A-7 2 12 screw Kits A-7 (螺丝包 -A7) A-7 1 13 Acrylic For End Stop (亚克力 -限位开关) A-8 2 14 screw Kits A-8 (螺丝包 -A8) A-8 1 15 X Carriage -Holde (亚克力 -X轴马车) A-9 1 16 screw Kits A-9 (螺丝包 -A9) A-9 1 17 Acrylic For Mainboard (亚克力 -主板) A-10 3 18 Mainboard Base (主板) A-10 1 19 screw Kits A-10 (螺丝包 -A10) A-10 1
B Fioor Gird Units
1 Step Motors (电机) B-1 4 2 Acrylic For Y Axis Front (亚克力 -Y轴前) B-2 2 3 Kits - B2 (螺丝包 -B2) B-2 1 4 Acrylic For Y Axis Black (亚克力 -Y轴后) B-3 2 5 Kits - B3 (螺丝包 -B3) B-3 1 6 Acylic For Heat bed Holder (亚克力 -热床底座) B-4 1 7 Kits - B4 (螺丝包 -B4) B-4 1 8 Acrylic For copper Holder (亚克力 -铜螺母) B-4-1 1 9 Kits - B4 -1 (螺丝包 -B4-1) B-4-1 1 10 Acrylic For Z Aixs Step Motor(亚克力 -Z轴电机座) B-4-2 1 11 Kits - B4 -2 (螺丝包 -B4-2) B-4-2 1 12 Belt (皮带) B-4 2 13 Wires Protection (绕线管) B-5 1 14 Acrylic For Z Aixs Right Holder (亚克力 -Z轴右) B-5 1 15 Kits - B5 (螺丝包 -B5) B-5 1 16 E3d & Cool Fan (E3D) B-6-1 1 17 Gift Kits (礼物套件) B-6-2 1 18 L aluminum Connector (L型材连接器) B-6-3 1 19 Tools (小工具) B-6-4 1 20 Acylic For Z Axis Left Holder (亚克力 -Z轴左) B-7 1 21 Kits - B7 (螺丝包 -B7) B-7 1 22 Feeder (送丝机 -B7 -1) B-7-1 1 23 Power Supply (电源) B-8 1
C Fioor Gird Units
1 End Stop (限位开关) C-1 3 2 Step Motors Wires (电机线) C-1 4 3 Wires of power supply (电源线) C-1 1 4 Plug (插头) C-1 1 5 USB Cable (USB线) C-2 1 6 Acrylic For Heat bed plate (亚克力 -热床) C-2 1 7 Heat Bed (Mk3热床) C-2 1 8 PTFE Tube (四氟管) C-2 1 9 Filaments (耗材) C-3 2
Photos
