Re: G&C Printer November 30, 2015 08:26AM |
Re: G&C Printer November 30, 2015 08:54AM |
Re: G&C Printer December 06, 2015 05:22AM |
Re: G&C Printer December 06, 2015 02:57PM |
Re: G&C Printer December 06, 2015 04:37PM |
Re: G&C Printer December 07, 2015 03:32PM |
Re: G&C Printer December 07, 2015 04:32PM |
Re: G&C Printer December 09, 2015 06:51AM |
Re: G&C Printer December 09, 2015 05:05PM |
Re: G&C Printer December 10, 2015 05:18AM |
Re: G&C Printer December 31, 2015 08:27AM |
Re: G&C Printer December 31, 2015 11:07AM |
Re: G&C Printer January 01, 2016 06:22AM |
Re: G&C Printer January 01, 2016 03:35PM |
Re: G&C Printer January 01, 2016 03:38PM |
Re: G&C Printer January 01, 2016 05:05PM |
critter42
Hi! I've been doing some looking around and I plan to make this my next build. I'll probably get started sooner, but it may take a month or more before I really get ramped up on this.
I did have two questions:
1) If I wanted to increase the build plate size, is there any issue with the cantilevered bed if I widen the Z axis rails? Also, what are your thoughts on adding a crossbeam between the two cantilever arms if I do so? I want a 250^3 or even 300^3 build volume.
2) I have access to a laser cutter and would rather laser cut the cover plates than print them - Are those in the 123d file?
3) I don't have any 20x40 or 20x60 - but I have shedloads of 20x20 - are there any issues to watch out for by clamping two or three pieces of 20x20 together to make the other sizes?
Danny
I using an 3mm aluminium plate secured on both arms and do the same job of the crossbeam. For bigger beg the crossbeam is an good solution.Quote
critter42
Re: G&C Printer January 02, 2016 03:16AM |
Re: G&C Printer January 03, 2016 02:56PM |
Re: G&C Printer January 03, 2016 03:45PM |
Re: G&C Printer January 04, 2016 11:09AM |
Re: G&C Printer January 04, 2016 12:49PM |
eviltoy
could i use this [www.3dprintingstore.co.za] instead of the SCV12UU as they are not available in my country
Re: G&C Printer January 11, 2016 12:10AM |
filipeCampos
3) i do not think it will work for the 20x60 used for the bed. For the 20x40, it was used to secure the 4 printed plates, in your case you will have only one big plate, so you can simply replace with an 20x20 or not use at all.
Re: G&C Printer January 20, 2016 06:49AM |
Re: G&C Printer January 20, 2016 07:24AM |
Re: G&C Printer January 20, 2016 12:32PM |
Re: G&C Printer January 20, 2016 12:48PM |
Re: G&C Printer February 03, 2016 04:22AM |
Re: G&C Printer February 03, 2016 04:56AM |
Re: G&C Printer February 29, 2016 11:14AM |
