G&C Printer August 28, 2015 09:37AM |
Re: G&C Printer August 28, 2015 10:40PM |
Re: G&C Printer August 29, 2015 06:55PM |
Re: G&C Printer August 31, 2015 01:46AM |
Re: G&C Printer September 02, 2015 07:37PM |
Re: G&C Printer September 03, 2015 04:40AM |
Re: G&C Printer September 03, 2015 09:32AM |
Re: G&C Printer September 08, 2015 05:55AM |
Re: G&C Printer September 08, 2015 04:26PM |
Re: G&C Printer September 09, 2015 05:04AM |
Re: G&C Printer September 11, 2015 07:54AM |
Re: G&C Printer September 25, 2015 09:54AM |
Re: G&C Printer September 25, 2015 12:50PM |
Re: G&C Printer September 25, 2015 01:30PM |
Re: G&C Printer September 25, 2015 01:49PM |
Re: G&C Printer September 25, 2015 03:43PM |
filipeCampos
Duet board is a good option, good and complete board, the version 0.6 is cheap. But if you live in Europe like me the duet it expensive because of the vat.
I order radds because is sells from germany (no vat),
Re: G&C Printer September 25, 2015 04:36PM |
filipeCampos
If you decide to build the same printer i can help you to build a better one. I have some suggestions/ideas to improve the g&c printer.
filipeCampos
My next improvement is to add to the design an direct extruder and replace my bowden.
Now i have an bowden extruder, is very reliable for pla and abs (never have any jam) but give me lots of problems with bobs and tiny filaments.
Bowden entruder and 1.75 filament is a very bad mix... If your are thinking about using an bowden extruder in your corexy them is better to build an printer that use 3mm filament.
Re: G&C Printer September 25, 2015 05:04PM |
Re: G&C Printer September 25, 2015 05:33PM |
Re: G&C Printer September 25, 2015 05:48PM |
David J
filipeCampos
Interesting... I'd like to know before I commit to spending money!
Re: G&C Printer September 25, 2015 05:54PM |
Re: G&C Printer September 26, 2015 05:19AM |
filipeCampos
the main objectify of the printer is to be cheap, the ideas/suggestions i have is to replace some components and add upgrades. I think at the end the cost will be less or at most the same..
Some ideas, some already added to my printer but there are not reflected in the 3d design.
for example:
-add an simple led switch on/off that cut the power. (already done)
-add an led light that allow me to see the printing, very useful to check the 1 layer. The light can be controlled by the firmware if you connect to the 12v of the second hotend not used. (done)
-min Z endstop can be micro adjusted with an screw (done)
-the lcd can be placed more inside the printer.
-one of the printed panel can have an box to put some tools.
-one of the printed panel can have nozzle holder, exemple: [www.thingiverse.com] this nozzle holder can be "inside" of one of the panel.
-replace 30A power supply for 20 or 25A
-buy the t-nuts from ebay, reduce 8€ total cost..
-design an carriage that allow dual hotend, it can be necessary to replace the y axis with 10mm
Re: G&C Printer September 26, 2015 06:02AM |
Re: G&C Printer September 27, 2015 10:30AM |
Re: G&C Printer September 27, 2015 01:13PM |
dc42
I have only ever used 1.75mm Bowden extruders and I generally find them OK. I agree that getting the right amount of retraction is critical. I have not tried to print flexible filament.
A non Bowden extruder light enough for a delta printer would be nice. I have it in mind to build one around a small BLDC motor with reduction gearbox, encoder, and microcontroller.
Re: G&C Printer September 27, 2015 02:26PM |
Re: G&C Printer September 27, 2015 06:37PM |
Re: G&C Printer September 28, 2015 03:41AM |
Re: G&C Printer September 28, 2015 05:02AM |
Re: G&C Printer September 28, 2015 05:18AM |
