Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:42AM |
gadget_greg
Mike, I've been using the zip ties that came with the kit and some similarly-sized ones from WallyWorld, 100 for $1.29! YMMV.
Bratan, IDK about the MOSFET grounding out but that z-axis stabilizer is similar but Tech2C's is a perfect fit. I printed part of that other one and it didn't line up well for whatever reason. It was easier for me to just use Tech2C's...
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 04:44AM |
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:07PM |
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:12PM |
LittleMike
Allnei
Problem is not in zip ties, problem is how do you use them You are tightening them backward, teeth are supposed to be facing inward in "ziptie loop"
The teeth are inward. If they weren't they wouldn't grip at all.
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:14PM |
alvinhochun
LittleMike
Allnei
In your photo it does seem like you got the zipties wrong. One side of the head is flat and the other is protruding, make sure the protruding end points outward.
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:18PM |
LittleMike
alvinhochun
LittleMike
Allnei
I think it's just the way it looks in the image. They're gripping, but on some, the teeth are "smoother" if that makes sense, so they slip.
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:21PM |
alvinhochun
LittleMike
alvinhochun
LittleMike
Allnei
Then you should switch to another one. There should be many more than you need, but even if you run out of zipties just buy more. They are dirt-cheap.
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:25PM |
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 12:26PM |
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 03:00PM |
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 03:02PM |
Allnei
I am almost sure from photo, that zipties are backward
My X carriage
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 03:39PM |
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 03:43PM |
gadget_greg
Those 3 screws hold the Extruder Assembly to the x-carriage.
All Walmarts are not created equal. Not only do prices for individual items vary from store to store but my informal analysis of their food prices shows that their prices aren't that great either. Roughly 50/50 for items I buy. Given that I almost never but food stuffs at WallyWorld. In fact I buy as little as possible there even though they're nearly the only game in town. #Bastards
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 04:48PM |
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 04:50PM |
Allnei
Reason why I have only 3 screws in X carriage is because my extrudes body is little warped and can´t be secured it with 4th screw
Re: My Replikeo Prusa i3 Rework Build August 23, 2014 11:36PM |
LittleMike
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 12:47AM |
vegasloki
LittleMike
That slipping is common in lower cost tie wraps even when installed in the proper end as well as stripping the teeth when they are tightened. Choosing a better quality part will solve the issue. If you don't have a good local hardware an auto parts store usually has them and lacking that Grainger has pretty good quality tie wraps you can get online. I'd avoid Walmart.
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 01:16AM |
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 11:33AM |
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 12:24PM |
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 04:21PM |
Well I fixed it. Problem was that I must've damaged traces when I was removing bad MOSFET, they lifted up on both sides. I fixed it by soldering short wire from R13 to MOSFET's Gate pin (1). I kind of suspect this trace might have broken before when I was bending MOSFET to fit Heatsink on it. Anyway it's no good that copper traces coming off so easily...Quote
gadget_greg
I'm beginning to thing that the RAMPS platform is pretty fragile. My Heat Bed will no longer sustain a temp, even a low temp like 60. It heats to a point then just cuts out. I have a relay I can use and bought just for this purpose but it's triggered by 5v and the MOSFET is 12v so I need to do a little research how to hook it up... :/
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 05:01PM |
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 09:52PM |
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 10:00PM |
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 10:02PM |
Bratan
Guys I has another issue with printer, which I kind of expected to happen since day 1. Those little m5 nuts that basically hold whole X assembly moving on the z axes along M5 threaded rods, are finally falling off. There's not much to hold them other than plastic fitting which get's loose with time. Is there a better design for this that anyone know of?
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 10:32PM |
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 11:16PM |
Re: My Replikeo Prusa i3 Rework Build August 24, 2014 11:21PM |
Bratan
Yes I mean X-motor mount and idler. They are not upside down, but sometimes hotend pushes on the bed, and nuts coming off. This happened few times already so they are not holding strongly. I'll try superglue, but this is quite obviously a flaw in the design...
