Re: My Replikeo Prusa i3 Rework Build June 25, 2014 11:19AM |
Bratan
I also might have issue with extruder part. I used only one screw with spring and filament pushed to the side and broke small piece of plastic that was guiding filament. It's probably not a big deal, but I wanted to ask, do you guys tighten extruder screws as tight as possible or it doesn't matter?
Re: My Replikeo Prusa i3 Rework Build June 25, 2014 03:03PM |
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 11:33AM |
Thanks! Yeah I was talking about idler. I added second screw and cut it so it doesn't push out motor.Quote
Allnei
Don´t use only one screw, because pressure on the filament is bad. Also don´t tighten iddler screws too much, because they will push motor on other side (they can go through). Bratan if you ask about tightening extruder screws (4 screws that hold X carriage and extruder) they must be tight, if not, your prints will not be good.
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 01:35PM |
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 02:29PM |
I used all default settings for speed.Quote
Allnei
What acceleration did you set? IMHO too fast movement, or too slow extrusion
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 04:57PM |
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 05:18PM |
I'm making this one.Quote
Allnei
What spool holder are you printing? I was thinking about this one [www.thingiverse.com] or this style [www.thingiverse.com]
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 09:46PM |
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 09:51PM |
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 09:52PM |
Did u order with DHL shipping? On mine tracking never really updated but I still got package about a week later.Quote
esponda
Hi, anyone else ordered the kit this month? I ordered mine on July 14, received my tracking number on July 19, but still showing traveling (from China to China !). And replikeo is not answering my e-mails u.u
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 10:21PM |
Re: My Replikeo Prusa i3 Rework Build June 26, 2014 11:11PM |
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 12:27AM |
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 08:02AM |
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 10:10AM |
It's measuring intake filament not outtake If you mark 5mm of filament (i.e. from top of the extruder) and extrude 5mm, filament should move exactly 5mm (i.e. your market will be at the level with top of the extruder). Do not measure what actually comes out...Quote
gadget_greg
@Bratan yes, that is very strange! When I set PronterFace to extrude, say 5mm, I get a superfine filament that curls all around and must be more like 20mm. It's really weird.
Wow, dude that's exactly what I was looking for! My spools opening is about 38.5mm and I was trying to adapt 30mm model I found on Thingivers.Quote
gadget_greg
Anyway, I just made one of these. It took a little dremelling to get the bearing to fit but it works nicely. I'm printing the second one now... [www.shapedo.com]
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 11:10AM |
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 11:16AM |
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 12:00PM |
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 01:05PM |
Bratan
BTW are there any advantages of using 1.5mm filament vs 3mm? I think thinner should be easier to thread, 3mm is just so inflexible...
Are you going to make something to attach it to the Prusa's frame?
Question to all: How did you wire your extruder cooler fan? I soldered it directly to Ramps aux board (as instructed) but now I'm having second thoughts. Has anyone connected it to the fan terminals (near heatbed terminals)?
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 01:12PM |
LOL, yeah I can imagineQuote
gadget_greg
I was wondering if that's where you measure it. I tried 100mm and I got a bird's nest! lol
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 03:11PM |
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 09:43PM |
Do you wipe glass or respray after each print? What about ABS, would harispray work for it too?Quote
gadget_greg
I've been spraying the glass with a light coat of Aquanet Super Extra Hold @ 60°C and I have had great adhesion. I'll do the extrusion calibration tonight when I get home, thanks for the tip! The last one graduates High School tonight...
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 10:43PM |
Re: My Replikeo Prusa i3 Rework Build June 27, 2014 10:59PM |
Re: My Replikeo Prusa i3 Rework Build June 28, 2014 03:02AM |
Re: My Replikeo Prusa i3 Rework Build June 28, 2014 02:25PM |
esponda
Yes I ordered via DHL. Still not received an answer from them :/
Re: My Replikeo Prusa i3 Rework Build June 28, 2014 02:34PM |
Re: My Replikeo Prusa i3 Rework Build June 28, 2014 07:12PM |
gadget_greg
Any idea of what kind of lubricant to use on the rails by the way?
Re: My Replikeo Prusa i3 Rework Build June 28, 2014 10:02PM |
Re: My Replikeo Prusa i3 Rework Build June 29, 2014 02:01AM |
underthetire
Man, i can see 1 issue I'm going to have. I'm used to industry standard gcode, I can see quite a few that don't look like they do the same functions as they would on machine tools.
