My Replikeo Prusa i3 Rework Build
Posted by Trike
Re: My Replikeo Prusa i3 Rework Build
August 24, 2014 11:26PM
alvinhochun
If your hotend pushes into the bed, then that's something you really should worry about instead, because it can damage the hotend or the print surface, or both.
In my opinion, it's good that the nuts actually come off, since it can reduce the chance of the hotend pushing into the print surface too hard and damaging them.
It happens occasionally, and I'm not the only person who this happened to (see Graig's reply above). Certainly not something that happens during actual printing, but during my manual calibration. In one instance I connected endstop incorrectly, and when homing z-axes didn't stop when it hit the glass, and by the time I pressed Emergency stop nuts were out sad smiley
August 25, 2014 10:31AM
Be happy that they pop out. If they were holding better, hotend would break your HB and probably destroyed your nozzle
August 25, 2014 07:42PM
Bratan
this is quite obviously a flaw in the design...
Actually it's a failsafe design. If the nuts were as secure as you think they should be, when the hotend hits the bed, it'll keep getting pulled into the bed, damaging the printer. That the nuts pop out when the hotend hits the bed keeps too much pressure from being applied to the bed, and prevents damage. Don't glue the nuts in!
MakerFarm 8" Prusa i3v
RAMPS 1.4
0.4mm E3D v6 for 1.75mm
August 25, 2014 08:59PM
Hey guys! Im looking to get into 3d printing and I cant decide whether to get a replikeo prusa i3 or a printrbot simple? Both are the same price. And if you say the replikeo, what vendor is the best to buy from?
Thanks
August 25, 2014 10:55PM
ksb24
Thanks
Wherever you buy from, be prepared to replace parts and upgrade the printer yourself. A DIY kit is different from consumer electronics in the way that you need to do it yourself.
August 26, 2014 04:50PM
AbuMaia
Thanks I was wrong about it, now I see it makes sense smiling smiley
ksb24
Thanks
I'd say go for prusa i3 smiling smiley But I don't really know anything about printbot simple, so don't listen to me smiling smiley
Guys can you recommend a mount for FAN that would cool PLA on HB? I'm getting really bad bridging issue, and read that cooling PLA should resolve it. I did try playing with temperatures of filament but it didn't help...
Also I took spool off the iron frame, and quality of print seems to improve. I think there was issue with too much flex and vibration. I'm printing Tech2C's version of Z-axes stabilizers now smiling smiley
August 26, 2014 06:14PM
Hi guys ,
I received my replikeo today. It was shipped via DHL (3 days from China -> Hong Kong -> Belgium) and all the parts were very well packed.
I have just a quick question about the RAMPS board. The power supply connection is a green terminal with 4 pins.
Should the other end of the terminal be included in the package or is this something missing in my box?
If not clear I can post a picture tomorrow.
Regards
Bert
August 26, 2014 08:34PM
Repelsteler
Hi guys ,
Regards
Bert
Yeah, there should be power block where you screw 4 wires from PSU and then you just plug that block into RAMPS board. Like on this picture.
August 26, 2014 10:24PM
The RAMPS should look exactly like this: [item.taobao.com]
August 27, 2014 03:56AM
Thanks ... seems my connector is missing sad smiley
August 27, 2014 05:28AM
Repelsteler
I suggest you contact Replikeo for that.
August 27, 2014 10:00PM
I'm trying to print with ABS that came from Replikeo with kit, but so far having strange issue. First layer sometimes prints in wavy lines. I searched for similar issue and didn't find anyone mentioning it. I tried various temperatures from 235C to 220C, best seems to be at 225C, but still fist layer is totally busted.
I suspect it could be problem with ABS material... Any suggestions? Also what temp do you use with Replikeo's black ABS?
open | download - 20140827_213345.jpg (75.7 KB)
August 27, 2014 10:59PM
Bratan
Seeing that wavy line is only on one axis, I suggest you check that axis.
August 27, 2014 11:15PM
alvinhochun
Hmm interesting, I didn't think it could be mechanical issue... It actually happens on both axes, and seems only after I switched to ABS, but that could be coincidence (I did install Z axes stabilizer system at about the same time...)
August 28, 2014 09:02PM
Hello everyone...
I just purchased the aluminum Replikeo kit!
I have recently read through this entire thread for tips so far. I am very excited for everything to arrive, and I can't wait to get printing.
So far I have ordered a glass bed plate from McMaster-Carr, PTFE Lubricant from Amazon, Aluminum stepper driver heatsinks from Ebay, and the Intelligent Controller from Banggood.
Any other things I should get that are important?
Also, what are some cool objects to print (or ones I should use to add on to my printer)? I'm looking for something to keep my mind busy while the printer ships smiling smiley
Hopefully it will arrive soon!
Blue Ice
August 28, 2014 11:06PM
Blue Ice
Hello everyone...
Blue Ice
Congrats! smiling smiley You didn't have to purchase heatsinks for steppers, they come with the kit.
I suggest you buy heatsinks for MOSFETs (one for HB and one for HE). I got these from eBay, they fit nicely but you can only fit two, not enough space for 3.
I'd print Z-axes stabilizer and Z axes endstop tuner. Don't forget to a spool mount. You can print one that can be mounted on the frame, but don't use it without stabilizers, or just build one out of PVC.
And order some PLA too. PLA is nice for quick prints because you don't have to heat up bed and hot end too long. With ABS I have to wait forever until HB heats up to 90-100C. And speaking of heated bed, get a piece of cork to insulate it from metal frame and speed up heating. Mine heats up to 60C in less than 2 minutes.
August 28, 2014 11:43PM
I got a roll of PLA already- but I will order those heatsinks too. Thanks for letting me know about that.
Bratan
What type of form should the cork be in? Can I use wine corks, or should I get a sheet of cork?
Blue Ice
blog at [contemporarymaker.com]
August 29, 2014 12:03AM
Bratan
OK, I just ordered 2 of the heatsink sets- thanks so much for recommending them to me. The part recommendations were helpful as well, and I think I will print those at first.
Bratan
I got the PLA from kbellenterprises on eBay- apparently, they are supposed to be good.
Thanks for all of the help, and I will let you know when everything arrives!
Blue Ice
August 29, 2014 10:25AM
Blue Ice
Sheet of cork, about same size as glass. 1/4" thick or less.
You ordered 2 sets of heatsinks? There are 10 pieces in each confused smiley I guess you'll have plenty of spares for future projects smiling smiley
Just be careful when you put them on, make sure none of the other MOSFET's heatsinks touch each other. Also heatsinks are threaded for M3 screws I think, but I was able to easily screw in 4-40 screws which might be easier to obtain if you are in the US... Have fun with your build! smiling smiley
August 29, 2014 05:04PM
Bratan
I'll probably get it at Home Depot or at Ace. M3 screws are at Ace as well. Thanks.
Bratan
Haha yes, I ordered about 20 because I wanted to get a couple extra for some LM317s and other random components that come in the same TO-220 package. Just got a bunch from Electronic Goldmine's random part kit, and I thought they would be fun to toy around with smiling smiley Also, it's a good price... 10 cents a heatsink isn't that much.
Bratan
I understand. Like in this picture:
This is why you can't put on all 3 heatsinks, hmm?
Edited 1 time(s). Last edit at 08/30/2014 12:50AM by Blue Ice.
Blue Ice
September 01, 2014 10:21PM
Hey guys.
I have had next to zero time to work on the printer lately, so I haven't made much progress. I did have a little time though, and I've reached a snag on getting the belts right. I put both belts on, but neither the x nor the y carriage seem to be able to hit the endstops. They run into the portion of the belt that's ziptied. Should I move the zipties closer? I can't figure out why I don't have enough room. Pics attached.
open | download - x belt.jpg (99.2 KB)
open | download - y-belt.jpg (87.8 KB)
September 01, 2014 11:21PM
I think I figured out my problem. Or at least one of them. Someone please clarify for me, if looking at the printer from the front, which way is the y-carriage oriented? Is the side with the two bearings on the left or the right? Also, which side is the motor mounted to, the left or right? I think I have my y-carriage flipped 180 and the y-holder is hitting up against the motor.
Edit:
Also, is the y motor mounted in the front or the back? Or can you put it in either place?
Edited 1 time(s). Last edit at 09/01/2014 11:26PM by LittleMike.
September 02, 2014 12:00AM
LittleMike
Yes. Either use one zip tie on each side, or put them side by side, and trim off the excess belt.
RAMPS 1.4
September 02, 2014 12:47AM
LittleMike
Doesn't really matter, it should be mostly symmetrical.
Though I see that in your photo the y-belt is aligned at the bottom of the belt holder, you may want to make it align to the top.
Also, make sure that the y-axis smooth rods has snapped into the y-corners. I needed to apply some force for it to snap in place.
LittleMike
Technically, either will work, but you might want all the wires to go through the rear end so you may prefer it being in the rear.
AbuMaia
LittleMike
Using two zip ties feels more secure, in case one of them fails. But try to keep them as close as possible.
September 02, 2014 12:52AM
alvinhochun
LittleMike
LittleMike
AbuMaia
It's not symmetrical. The "bumps" that hold the y-belt will stop at the motor if it's on the wrong side. Well, I guess you could put the carriage either direction, but the motor would have to go on the other, so in a way symmetrical, in a way not. Haha.
Any particular reason why I should align them to the top? You mean the way the loop goes, correct? I was just following the images in the build manual. Which seems to have gotten me into almost all the trouble I've had in this build with things being backwards. tongue sticking out smiley
Yea, I'm moving it to the rear. It seems to make more sense that way. I also have to flip the endstop then, I think, no?
LittleMike
Okay, I will trim them down. I have them off now to adjust the motor and everything, but they seemed to catch. They would go smooth in one direction, but when I tried the other direction, they would "skip" so to speak. Same with x-carriage belt. Why is that?
Edited 1 time(s). Last edit at 09/02/2014 12:54AM by LittleMike.
September 02, 2014 02:47AM
LittleMike
Does it? Mine doesn't.
LittleMike
Which manual are you following? I mostly followed the RepRap wiki [reprap.org] and no such problem at all. (Though do note that some instructions may not apply directly.)
LittleMike
It's difficult to tell from text, but you should not need to flip endstops...?
The thing with DIY is that you can't always just follow instructions, but you also need to apply your own thinking.
September 04, 2014 06:43AM
Hi ,
Can anyone point me in a direction for auto bed levelling for the replikeo?
Thanks
Bert
September 04, 2014 06:07PM
Repelsteler
Hi ,
Thanks
Bert
Never worked with a 3D printer before, but I've seen that this design is popular: http://www.thingiverse.com/thing:182889
And a video for installation is here: https://www.youtube.com/watch?v=awsI9bMndJA
I might try it sometime, so I think it is a good idea.
Edited 1 time(s). Last edit at 09/04/2014 06:07PM by Blue Ice.
September 04, 2014 06:11PM
Blue Ice
Repelsteler
Hi ,
Thanks
Bert
That page says there is a new better way here:
[www.thingiverse.com]
Please note, I have not tried either method. Just pointing that out.
September 04, 2014 06:59PM
LittleMike
Blue Ice
Repelsteler
Hi ,
Thanks
Bert
I saw that one, but I didn't understand it smiling smiley Thanks for pointing it out.
