Re: My Replikeo Prusa i3 Rework Build July 17, 2015 08:31AM |
Re: My Replikeo Prusa i3 Rework Build July 17, 2015 11:51AM |
) and it has the connector pins already soldered to the board.
Re: My Replikeo Prusa i3 Rework Build July 17, 2015 05:30PM |
psneddon
Some boards have the connector pins soldered to the board and some don't.
After I finished my build I noticed my Ramps 1.4 board didn't come with the connector either.
I didn't want to solder the wires to the board since I already had everyhting plugged in and running, so I ended up stripping the wires and hooking them up to the D9 plug on the Ramps board.
I have been printing fine with the fan wired to the D9 plug as shown in the picture as "Print Fan (optional)"
I purchased a second Ramps board for back up (or next build) and it has the connector pins already soldered to the board.
Re: My Replikeo Prusa i3 Rework Build July 17, 2015 08:29PM |
Re: My Replikeo Prusa i3 Rework Build July 19, 2015 03:29AM |
chicky
Wow, it seems my post from July 4th weekend never posted…I must’ve been in too much of a rush to get out and shoot fireworks!
Ano, BlueIce, clone: this post from July 4 had a detailed breakdown of my problem and how your input helped my find the solution. I wanted to thank you for the help!
repramon:
Question 2: I believe this is fiberglass. That’s what Replikeo tells us anyway. I ended up ditching it for a 3 mm thick piece of 8”x8” glass to keep the build surface flat. I’m willing to bet you could print on this without tape, which is what I’d try first. If you’ve got everything set up right (level bed, proper distance between nozzle and build surface, correct bed temperature) and it doesn’t work, you could then try with the tape. I’ve never printed on it so I wouldn’t know for sure.
Question 3: Thermistor should contact the fiberglass surface. This ensures an accurate reading of the temperature of the fiberglass, which needs to be at 110 deg C or so for ABS printing. There is a little hole in the heated bed PCB you can stick the thermistor in such that it makes contact with the fiberglass from underneath. You could also tape the thermistor to the top surface of the fiberglass for possibly an even more accurate reading.
Question 4: I don’t know what these are for. I’d like to know myself as I didn’t use them when building the kit.
Hope this helps
chicky
Re: My Replikeo Prusa i3 Rework Build July 19, 2015 05:26PM |
Re: My Replikeo Prusa i3 Rework Build July 20, 2015 04:03PM |
Re: My Replikeo Prusa i3 Rework Build July 20, 2015 04:15PM |
repramon
1. What is home? Is it position where printer starts? i have followed Tech2c's this post. So my home is where X=200, Y=0, Z=0? Does that mean HE should be placed lower right corner and HB should be placed to backward side of printer?
repramon
2. If i manually move HE to -X direction and it moves, but it stops at some point and never moves further. it seems printer doesn't understand where x=0 is, it should be more further to -X. Same thing happens to other axises. How i configure it?
repramon
3. Extruder fan doesn't work. Does it work automatically when printing or should i trigger it using some method? Anyway it wired to D9 on RAMPS.
repramon
4. HB temperature is climbing up so slow. It took nearly 50 minutes to reach 106.9C and so far. In HE case, it is quick to reach 230C in a minute. Have you ever experienced same thing?
Re: My Replikeo Prusa i3 Rework Build July 20, 2015 05:05PM |
repramon
manually running fan with below command works.
M106 S$ (where $ is 0 to stop fan, 1-255 to run fan)
repramon
is this related to PIDTEMPBED? In configuration.h file, PIDTEMP is present and not PIDTEMPBED.
Re: My Replikeo Prusa i3 Rework Build July 20, 2015 05:11PM |
repramon
4. Whats are those for?
Those are maybe for motors? (because screwing is not tight enough)
Anyway those couple holes are matched with of motors.
Re: My Replikeo Prusa i3 Rework Build July 23, 2015 09:43AM |
Re: My Replikeo Prusa i3 Rework Build July 23, 2015 05:31PM |
Re: My Replikeo Prusa i3 Rework Build August 16, 2015 05:05PM |
Re: My Replikeo Prusa i3 Rework Build August 20, 2015 06:47PM |
Re: My Replikeo Prusa i3 Rework Build August 20, 2015 08:00PM |
Ano
Hey LittleMike,
never give up! ^^
Did you check the temperature? Perhaps the thermistor isn't working properly. A too low temperature could be the problem.
If that's not the case, try to tighten up the nozzle while being heated to 230°C. Perhaps there is a little gap that's blocking the
filament to flow. Other than that: Try not to turn the tensioners in too much, otherwise it could also have a negative effect (if you
see deep marks on the filament, it's tight enough).
To clean the nozzle, try heating it up (a bit lower temperature than while printing, don't want to get the filament liquid, just soft
and pulling out the filament, then put the filament back in and pull out again. Repeat. untill it's clean ^^
Re: My Replikeo Prusa i3 Rework Build August 20, 2015 08:42PM |
Re: My Replikeo Prusa i3 Rework Build August 27, 2015 01:25AM |
Ano
Did you check if 230 degrees are "real"? Or is it just the electronics showing that value. Try to check with another thermometer.
My idler sits on a slight angle, too. Perhaps you should try to find a solution without the nozzle installed. Just check the extruder
itself.
Is your hobbed bolt working correctly?
Re: My Replikeo Prusa i3 Rework Build September 01, 2015 02:00AM |
Re: My Replikeo Prusa i3 Rework Build September 01, 2015 03:53PM |
// 60 is 100k Maker's Tool Works Kapton Bed Thermistor beta=3950 #define TEMP_SENSOR_0 60 //Ano #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 60 //Ano
Re: My Replikeo Prusa i3 Rework Build September 01, 2015 04:29PM |
Re: My Replikeo Prusa i3 Rework Build September 02, 2015 09:44AM |
You mean the value that Repetier shows? Or the one on the display attached to the Ramps (if you have one)?Quote
Googlynz
[...] then temperature readings are zero.[...]
Re: My Replikeo Prusa i3 Rework Build September 03, 2015 05:54AM |
Re: My Replikeo Prusa i3 Rework Build September 03, 2015 09:55AM |
Re: My Replikeo Prusa i3 Rework Build September 03, 2015 04:45PM |
Re: My Replikeo Prusa i3 Rework Build September 07, 2015 12:39AM |
Re: My Replikeo Prusa i3 Rework Build September 07, 2015 10:52PM |
Re: My Replikeo Prusa i3 Rework Build September 09, 2015 10:34AM |
Re: My Replikeo Prusa i3 Rework Build September 09, 2015 06:53PM |
Re: My Replikeo Prusa i3 Rework Build September 10, 2015 07:29AM |
Re: My Replikeo Prusa i3 Rework Build September 10, 2015 07:34AM |
