Re: My Replikeo Prusa i3 Rework Build June 15, 2014 11:56AM |
Yea no problem, I realized that when I saw size of the compiled file (over 120K vs. 56K usual) so I figured it was due to LCD and or SD cardQuote
gadget_greg
I just realized that the configuration.h file that I uploaded is configured for a Full Graphics LCD Controller. You'll need to comment out this line:
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Sorry about that! My config has changed a little since then too...
SENDING:M105
ok T:20.0 /185.0 B:31.7 /0.0 T0:20.0 /185.0 @:127 B@:0
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 12:25PM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 12:46PM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 12:59PM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 01:16PM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 07:48PM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 08:05PM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 08:40PM |
Thanks for the info! I just installed it, it's not super easy to configure tho Do you mind sharing your config file to get me started? I'll modify it as needed.Quote
Allnei
Guys, don´t know why you don´t want use another FW, but I had many problems with endstops, axis movement etc. with Marlin. When i switched to Repetier 99% problems were gone. Repetier is imho more user friendly with their web config tool and they have nice host (Repetier Host)
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 09:41PM |
Re: My Replikeo Prusa i3 Rework Build June 15, 2014 10:07PM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 02:32AM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 05:33AM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 09:21AM |
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1
// ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 09:41AM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 09:50AM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 10:37AM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 10:41AM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 11:06AM |
Cool got it!Quote
Tech2C
Brantan, that photo I found on google images as it had the connector zoomed. I didn't edit it. Disregard the missing row of pins, just look at each set of pins from left to right as normal.
The coordinate system is relative to the print surface viewed from above. From left to right is 0 to 200. Bottom to top is 0 to 200.
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 02:43PM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 02:58PM |
Congrads!Quote
gadget_greg
My Home is diagonally across from where yours is.
My X-axis motor is reversed from what's pictured here (body facing 'back'). I can't see your Y-motor.
Endstops are all in the same places.
All motor wires are Green-down (closest to the power plug).
All endstops are plugged into MIN.
Z_DIR false
#define INVERT_E0_DIR true
#define Y_HOME_DIRMy config:
#define INVERT_X_DIR true
#define INVERT_Y_DIR true
#define INVERT_ -1
My prints are finally oriented correctly.
I'm still using Marlin/Pronterface but I'm looking into Repetier...
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 03:41PM |
Re: My Replikeo Prusa i3 Rework Build June 16, 2014 05:46PM |
Re: My Replikeo Prusa i3 Rework Build June 17, 2014 01:03AM |
Cool got it!
So since my Y endstop is in the back, it will become MIN since it's touched when Y is at 0 right?
I made a quick sketchup model (img attached) with my understanding of the Prusa i3 axes and coordinates. Is it correct?
Re: My Replikeo Prusa i3 Rework Build June 17, 2014 05:54AM |
Re: My Replikeo Prusa i3 Rework Build June 17, 2014 11:35AM |
Re: My Replikeo Prusa i3 Rework Build June 17, 2014 05:55PM |
Re: My Replikeo Prusa i3 Rework Build June 18, 2014 05:25AM |
Re: My Replikeo Prusa i3 Rework Build June 18, 2014 06:24AM |
Re: My Replikeo Prusa i3 Rework Build June 18, 2014 06:32AM |
Re: My Replikeo Prusa i3 Rework Build June 18, 2014 11:06AM |
