Re: My Replikeo Prusa i3 Rework Build February 22, 2015 03:08AM |
Ano
Tried to update my printer:
[attachment 49782 IMG_20150222_011708.jpg]
Direct drive extruder at the top frame with 45° mount angle.
Now I just need to fix the extruder:
https://www.youtube.com/watch?v=b4G1odhli3I&feature=youtu.be
I'm not sure what's causing this motor behavior. I would understand the gear not being able to pull/push the filament, but this "jumps"
are a bit strange.
Re: My Replikeo Prusa i3 Rework Build February 22, 2015 03:11AM |
mr.sneezy
Update on my Prusa i3.
The printed parts on my machine are made of PLA. Yesterday the shed where it's used was 40C ambient in a bit of Aussie hot weather. You'd think that would make for nice printing as the print would not cool so much between layers.
Well about 15 minutes into the print the Wade extruder assembly softened up and drooped by about 10mm, ruined the print of course, and the Wade extruder holder. The X-carriage is also warped.
Now getting those parts reprinted in ABS.
Martin
Re: My Replikeo Prusa i3 Rework Build February 22, 2015 07:57AM |
Re: My Replikeo Prusa i3 Rework Build February 25, 2015 09:46PM |
Re: My Replikeo Prusa i3 Rework Build February 26, 2015 06:45PM |
Michaelj
Does anyone know of a comparable kit in the United States?
Shipping alone is $100.00US unless I wait for 60-90 days
Which is $46.00US.
Re: My Replikeo Prusa i3 Rework Build February 28, 2015 10:33AM |
Blue Ice
Hey guys-
Ano, thanks for mentioning the picture confusion with whether the motor should be at the front or the back. I fixed it in the introduction post and added a note that the motor should be at the front as per the build instructions.
I also got the next build log post published, covering the extruder setup. It seems that you won't need it after all, though, because you have a different extruder! But other people might find a use for it at some point, so we'll see.
Re: My Replikeo Prusa i3 Rework Build March 01, 2015 05:51AM |
Re: My Replikeo Prusa i3 Rework Build March 01, 2015 07:36AM |
Re: My Replikeo Prusa i3 Rework Build March 01, 2015 08:24AM |
Re: My Replikeo Prusa i3 Rework Build March 01, 2015 09:46AM |
Re: My Replikeo Prusa i3 Rework Build March 01, 2015 10:43AM |
Re: My Replikeo Prusa i3 Rework Build March 01, 2015 11:02AM |
Re: My Replikeo Prusa i3 Rework Build March 01, 2015 11:18AM |
Re: My Replikeo Prusa i3 Rework Build March 02, 2015 10:58AM |
Re: My Replikeo Prusa i3 Rework Build March 02, 2015 05:41PM |
psneddon
Blue Ice
Hey guys-
Hey Blue Ice! I just finished skimming through your latest build blog. Your extruder looks pretty much like mine. I still have to buy a hobbed bolt for it. Do you know what length of hobbed bolt is it and where is the center of the hobbed portion in relation to the bolt head or end?
I am getting ready to buy my heated bed and I'm trying to find the right thermistor to use for a MK2B style HB. In the configurations.h file there is a list of thermistors. I believe you had mentioned before to use either options 1,5 or 8. Is this correct? I am thinking of going with #5 an ATC Semitec 104GT-2. Would that be a good selection?
Re: My Replikeo Prusa i3 Rework Build March 02, 2015 05:44PM |
Michaelj
Blue ice...when you ordered you PRuse i3 Rework from Replikeo, what extras other than the LCD screen and glass heatbed did you order?
Re: My Replikeo Prusa i3 Rework Build March 03, 2015 07:42AM |
Bratan
I finally added LCD smart controller (have been printing from PC all this time). I'm a little confused tho, I get no power to the ATMegal when using just PSU. If connect USB everything works. RAMPS doesn't power ATMega?
Re: My Replikeo Prusa i3 Rework Build March 03, 2015 02:51PM |
Re: My Replikeo Prusa i3 Rework Build March 03, 2015 06:02PM |
Re: My Replikeo Prusa i3 Rework Build March 04, 2015 10:15PM |
Re: My Replikeo Prusa i3 Rework Build March 05, 2015 09:20AM |
Re: My Replikeo Prusa i3 Rework Build March 05, 2015 05:40PM |
Re: My Replikeo Prusa i3 Rework Build March 06, 2015 04:10PM |
Re: My Replikeo Prusa i3 Rework Build March 06, 2015 04:36PM |
psneddon
Blue Ice,
Yes please! I never say no to information!
The hobbed bolt I'm waiting on supposedly has the center of the hobbed portion at around 28.5 mm from the bottom of the bolt head.
Re: My Replikeo Prusa i3 Rework Build March 06, 2015 05:01PM |
Blue Ice
psneddon
Blue Ice,
Mine was about that much as well, so you should be OK.
Re: My Replikeo Prusa i3 Rework Build March 06, 2015 05:17PM |
Re: My Replikeo Prusa i3 Rework Build March 07, 2015 09:16PM |
Ano
Hi guys,
long time no read. My 40x40mm fan broke =(. It was already damaged when I build my printer, but now it just broke appart. I ordered another one, after the new one from replikeo took too long to arrive,
the Scythe Mini Kaze. It only turns at 3500 rpm, but I think it's still enough air ventilation. And it's so much less noisy. Costed around 7 €, which was a good investment I think.
So, I'm back in business now =)
Ano
I try to find a good config for my bowden setup and would be great to get some tips from you =)
I currently have the problem, that after each retract, when the extruder turns back (re-retracts?), there is a blob of abs forming under the nozzle. Someone told me to decrease the retractspeed, I had it at
100mm/s, now it's at 40mm/s but I don't think it helped much. Should I try even lower values, or are there any other things I could do?
I have 5 mm retraction right now, which seems to be not enough, as some strings still appear. Should I try the option "extra lenght on restart"? Like setting it to -1mm, so that it retracts 5mm but only re-retracts 4?
Using slic3r btw. And the "wipe while retract"-option just seems to not change anything.
Also my printer seems to retract really often. Set the minimum travel after retraction to 1mm, should I raise it a bit?
Ano
Btw, my extruder works just fine now. Raised the motor current a bit and adjusted the tension of the screw to hold the filament.
When I ordered my printer at replikeo, I just added the LCD screen. It's the full pixel-matrix screen now, even if they didn't upgrade their page. And having all the parts (appart from wade extruder) as injection molded
pieces is kind of nice =)
Ano
Does anyone use cablechaines for the Prusa i3 rework? I would like to add some, I like the style =) Will try to add one from the electronics to the left z-axis-guide and another one from the guide to the hotend.
Re: My Replikeo Prusa i3 Rework Build March 07, 2015 09:38PM |
Re: My Replikeo Prusa i3 Rework Build March 07, 2015 09:42PM |
psneddon
Blue Ice
Thanks again. I'll check mine over once I receive it in the mail.
I received my MK2B heated bed and hooked up the wires to it and measured the resistance and I'm getting 2.6 ohms. Most of the information I've read about this heated bed states that the resistance should be 1.2 to 1.3 ohms. Is this correct?
I have the negative lead hooked to pad #1 and the positive lead hooked to pad #2 for a 12 volt supply - as stenciled on the heated bed.
I haven't hooked it up to any power yet and definitely not to my Ramps board until I test it. I have a DC power supply that can put out 3 amps of power at 12 volts, but I think the bed can take a higher current - is that so?
Re: My Replikeo Prusa i3 Rework Build March 07, 2015 09:48PM |
Bratan
What do you guys think about using MK8 hobbed pulley instead of hobbed bolt? This completely eliminates all the gears from extruder! All you need is bearing pushing filment onto pulley. Of course this requires different design for extruder but I'm sure there are many on Thingiverse...
